DesignSeries05076.pngSpring calculator
Command
Workspace: Path
Spring Calculator
Architect: AEC > Machine Design
Landmark: Landmark > Machine Design
Spotlight: Spotlight > Machine Design
The Spring Calculator command solves for spring rates and unit stresses based on compression spring parameters.
To calculate a spring rate:
Select the command.
The Spring Calculator dialog box opens.
Edit the compression spring parameters.
Parameter
Description
Units
Sets the spring dimension units to Inches, cm, or mm
Method
Select the method; as data is entered, the other dimensions are automatically calculated
Dimensions
The fields available depend upon the Method and the Type of Ends selected
Outside Diameter
Enter the outside diameter
Mean Diameter
Enter the mean diameter
Wire Diameter
Enter the wire diameter
Solid Height
Enter the solid height
No. of Active Coils
Enter the number of active coils
Type of Ends
Select Closed and Ground, Open and Ground, Closed, or Open to set the type of ends on the spring
Properties
The properties of the spring can be selected from the list or manually entered
Material
Select the material to be used for the spring or select <Other> to set the Modulus of Elasticity manually
Mod. of Elasticity
Automatically entered based on the material selected; displayed in pounds per square inch, newtons per square centimeter, or newtons per square millimeter, depending on selected units. If <Other> is selected, enter the Modulus of Elasticity manually.
Spring Rate
Automatically calculated based on the spring parameters; displays in the selected units
Unit Stress
Place 2D spring on drawing
Draws a 2D spring according to the above parameters; if both check boxes are selected, the 2D and 3D springs are automatically aligned in the drawing
Place 3D spring on drawing
Draws a 3D spring according to the above parameters; if both check boxes are selected, the 2D and 3D springs are automatically aligned in the drawing
Click Close to exit the calculator.
